but it works sporadically.
Whats weird is, it wasn't functioning at all on any settings....so I pulled the shroud open (exposing the blower), and kind of spun it a little and it started to work. It worked on all settings. I then proceeded to turn the car off, and try it again....no luck. So I pulled the resistor (which was recently replaced), and checked to make sure the values were right:
and they were within spec. I sprayed down all the leads, resistors & brushes on the motor w/ QD electronics cleaner, and it seemed to have helped....although it seems to still work in spurts.
Question I have is, does this sound like a bad motor? Like I mentioned earlier, when it wasn't functioning....i spun the motor w/ my fingers to give it a head start....and it worked.
- 1.6 Ohm
- .9 Ohm
- .35 Ohm
