Can someone show me a pic of a 325ix brake resevior....
    He said he HAD one so I hope he can enlighten us.
    Im now E30less.
      sheeit, I hadn't used the ix booster yet, I used modified 320i boosters on all of mine, except one actually... we used an alfa romeo booster that worked absolute wonders. No idea what model it came off of though :oops:
      Instead of using a remote resirvoir, I would look into raising it enough to clear the intake boot.. you'd have to use some kind of straight pipe
        Well I guess I will find out. Gonna try the remote. I dont really want it any higher, just needs to be moved over some.
        Maybe modify the remote system or use some sort of flexible hose like what runs to the clutch.
        Im now E30less.
          Bryson, what MC can I use with the 320i booster to go to four wheel discs?
            You can use a pre abs MC on the 320 booster or you can t-tap your front ones and run an uprated 535 or 735i MC.
            I would t them, its the same thing that the ABS system does, divides the fronts at the ABS pump instead of at the MC like ours do.
            Im now E30less.
