Deleting the rear antenna w/aftermarket
  • cbouchez
    • May 2007
    • 2789
    Any of you guys have the aftermarket antenna located on the rear windshield flat black bar. I’m thinking about repainting my car and the antenna is not working I really don’t like the antenna on the side or visible at all and now would be a good time to covering the hole. Any ideas or reviews about this time of antennas?
    Thanks,
    C
    Follow my IG @bouchezphotography
  • gearheadE30
    • Jun 2007
    • 3734
    What flat black bar? I suppose you could get a basic antenna and lay it across the back of the rear parcel shelf against the back window so you can't really see it, but I'm not sure how reception would be.
    Project M42 Turbo
    • cbouchez
      • May 2007
      • 2789
      I talked to the stero shop and they told me that they can hide the antenna under the dashboard and reception would be good, but I still have my doubts.
      • tjts1
        • May 2007
        • 1851
        Just hook up the antenna wire to the rear window defogger. It works great on my car.
        • dude8383
          • Jan 2005
          • 10387
          woah, what do you mean? did you hook it up in the back?
          • cbouchez
            • May 2007
            • 2789
            +1^^ How do you do it?
            • StereoInstaller1
              GAS
              • 22679
              If you simply hooked the antenna wire up to the rear window defogger and didn't fry the radio, luck was on your side.
              Sending +12V into your deck is certain death.
              OP: Please learn to use something near proper sentence structure, grammar, and syntax.
              Other people need to learn from your posts. Please make them clear, OK?
              Now, on to your antenna dilemma...
              The most common boat antenna that I use is a flat black strip, about 30" wide. It has a cable coming off of a center mounting point. You could easily install it in the rear window.
              Personally, I fucking HATE radio, so I don't even have the ability to use AM/FM in my car.
              Closing SOON!
              Thanks for 10 years of fun!
              • morningsmiler
                • Jun 2008
                • 230
                Luke...although I support your efforts, I fear you may be fighting a losing battle. Just look at joehasane30's posts for confirmation
                • gearheadE30
                  • Jun 2007
                  • 3734
                  lol. BTW if you want a working antenna, I have one for sale for $35 ;). /thread jack
                  Project M42 Turbo
                  • dude8383
                    • Jan 2005
                    • 10387
                    thank you! i don't want to fry anything :)
                    • tjts1
                      • May 2007
                      • 1851
                      Seriously? Do I need to spell this out to you guys step by step? Isn't it obvious? Disconnect the 2 wires on either side of the rear defogger (how often do you use that thing anyway) and connect the antenna wire to the driver's side connector on the defogger. Done. The defogger is insulated from the rest of the body of the car so it makes a perfect antenna. In fact a lot of cars have the antenna built into the windows from the factory. On my car receptions is slightly better than stock. I've had this setup ever since I filled in the antenna hole and repainted the car over a year ago.
                      • StereoInstaller1
                        GAS
                        • 22679
                        So you aren't just PLAYING dumb, huh?
                        Closing SOON!
                        • tjts1
                          • May 2007
                          • 1851
                          Booyah!
                          • deathtomine
                            • Jun 2008
                            • 206
                            Props, nice mod.
                            • Jparkr
                              HR Admin
                              • Jan 2006
                              • 3494
                              I wanna know where you live where the rear defog is not, ever needed...
                              1987 PRO-3 car /1990 325is (2.7i Concours)
