engine running hot
  • Matto
    • Jan 2004
    • 800
    engine running hot
    My engine has started running between the halfway and 3/4s mark on the temp gauge. It used to be planted on the 1/4 mark after it got warmed up. Any ideas what tit could be?
  • Fred
    • 659
    I don't know which tit would solve the problem ;). But usually if a car runs hot, usually the thermostat is stuck or there isn't proper circulation in the water pump or radiator. The way I figure, thermostats are cheap and easy to replace so that's the first thing I'd check.
    '86 325 2.8i stroker - Arctic Blue
    '11 328i Sports Wagon - LeMans Blue
    Strictly Eta
    • Rob
      • 8166
      change the thermostat and bleed the system. if that doesnt work, maybe your fan clutch is going bad
      BEERTECH
      • Matto
        • Jan 2004
        • 800
        Ok, thanks.
