Can I put a 325i cluster in an E
  • Brian 89 325i
    • 1450
    I have the cluster out of my 89 "i" and I was wondering if I can just plug it in to my 87 "e"? Will everything be accurate?
    Brian
  • lordofthewaters
    • Oct 2005
    • 714
    You can use it. Just make sure you switch the "i" coding plug for the eta one.
    Sarcasm is a body's natural defense against stupid.
    When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
    "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
    Old age and treachery will always overcome youth and skill.
    • Jparkr
      HR Admin
      • Jan 2006
      • 3494
      Just be careful if you do. If you have/or will have a chip that removes your revlimiter, then you may wanna think again. Especially if you ever let someone else drive the car and they over rev it because they don't know where the redline was originally ment to be.
      is there anything wrong with your E cluster, or are you just doing this cause you want to?
      1987 PRO-3 car /1990 325is (2.7i Concours)
      • Brian 89 325i
        • 1450
        The tach in my E is all wacky, and the odo is broken. I already replaced the gears in my old cluster.
        Brian
        • tonytony
          Knee deep in poopie
          • Jan 2004
          • 3498
          it'll make the e seem super-ultra-mega fast, if you dont switch the coding plug
          • SpecM
            • Oct 2005
            • 4531
            the revlimiter in the DME, not the cluster
            1989 cirrisblau-metallic 325i
            • Naplm00
              • Nov 2008
              • 1573
              ive got an E cluster with broken odo but all other working gauges
              PM if you want it
              88 325ic ~~~> Rusty and ugly
              85 E ~~~> RIP
              • Brian 89 325i
                • 1450
                Which plug do I have to swap out? Got a pic of it?
                BRian
                • lordofthewaters
                  • Oct 2005
                  • 714
                  It's on the bottom right hand corner of the front of the cluster.
                  • ieatpeople
                    • Mar 2008
                    • 883
                    i did this without thinking, and the only difference was that the tach no longer worked, but all the other gauges did.
                    Originally posted by BillBrasky
                    That's like Vlad challenging Chip Foose to a car painting contest.
                    Originally posted by acolella76
                    i'm pretty sure 'Phillis' is short for syphilis
                    2007 CVPI, stock and slow
                    1994 tercel, 5efhe swap, i/h/e
                    1984 t-type, 5.3/th350 swap in progress
                    My newest addition:
                    Rebecca Arlene, born 4/19/2013
                    • cferb
                      • 1442
                      He's saying that if you have a chip, and no rev limiter, then you have to worry about revving too high, because you won't be able to see the redline anymore. But if you have a rev limiter still it doesn't matter as it will stop you if you forget where the redline was.
                      • SamE30e
                        • Sep 2007
                        • 4319
                        Wtf... No..
                        The rev limiter is in the ECU.
                        1985 325e 2.8 Turbo VEMS
                        • Brian 89 325i
                          • 1450
                          So i swapped in the cluster and everything is accurate, but my fuel says I have a half tank more than i really do, and the gas light comes on just below half. So should I just swap the fuel unit from my E cluster back in?
                          Brian
                          • Kerrath
                            • Jun 2008
                            • 577
                            Put the e gas gauge in the i cluster. The senders are different. I did the same for mine and it works fine.
                            • Brian 89 325i
                              • 1450
                              I did and I had the same problem
