Does no oil mean no start?
  • napabavarian
    • Jun 2008
    • 834
    I wanted to make sure my new oilpanless 325ic turns over smoothly before going to all the effort of adding an oilpan, but it won't crank over, no click, headlights don't dim... If the sensor reads no oil does it override the starter relay? I don't need to start the engine, just hear it turn over a few rotations.
    This place is like catholic school, 2/3 of the students smoke weed on a daily basis, but the faculty seems to convince the outside world that drugs are just in the other schools, the resident pot dealer thinks he's cool because he has the originality to call anyone he doesn't like a homosexual, and most of the little children follow him like sheep, then there's the few with brains, you hardly ever hear from them, perhaps don't even know they exist, but they get all the sh!t done.
  • Rhys
    • Jul 2008
    • 103
    IT should still crank over, the car I picked up had it's oil pump shaft snapped into two pieces so there was no oil pressure. The car would still run let alone crank over, infact the car could still run with a seized piston and con rod twisted and snapped into three pieces! Sorry when I originally read you post I thought you were taking about the oil pressure sensor, not the oil level sensor. That being said I havent heard of it over riding the starter relay, I would think you could still crank it.......if not, why not just hook up the sensor and put it in a container filled with oil.
    • kronus
      • Apr 2008
      • 13028
      I have started mine with no oil briefly. It's not recommended (obviously) but the electrical system does not prevent it.
      cars beep boop
      • Jordan325iC
        • Aug 2005
        • 1697
        The main engine ground straps onto the driver's side of the oil pan. If you don't have the engine grounded, it won't run.
        '88 325is
        VP UT of Austin Autoholics
        BMWCCA 380364
        • napabavarian
          • Jun 2008
          • 834
          silly little details, thanks!:up:
          • napabavarian
            • Jun 2008
            • 834
            Jumper from the battery to the engine and she cranks quite strongly
            • SpecM
              • Oct 2005
              • 4531
              can't believe I didn't think of that!
              1989 cirrisblau-metallic 325i
              • Tree18is
                • Mar 2004
                • 2703
                this one time, I slid my e30 into a curb and cut off the bottom of the pan including that ground... car no start *panic* and tried to drive away lol
                oh 16 was a fun time.
                • Rolla1990
                  • 199
                  Don't crank too much you'll scuff those bearings!
                  Turbo M20, MSnS, 38lb, 3" no cat, RPI 12.2", ATS DTC, 240whp/240wtq, Lmnop. www.DonsGarage.net
                  • napabavarian
                    • Jun 2008
                    • 834
                    Just enough to hear it go, less than a cold start ;)
                    • einstein57
                      • Jun 2007
                      • 10780
                      Mine will barely run when if i leave the dispstick ajar
                      www.gecoils.com
