Sunroof broke last night RAINING
  • elemental
    • Jan 2004
    • 112
    Well the fun roof decied to break last night, hoping it is just off track or something.. never taken one apart but i have found that the pass side wire, for lack of a better term will go backwards but dose not whant to go forward, I allso discoverd that there was a bolt missing holding the pannel to the tracks, not sure if this is what created the prolbrem but it has been working just fine.,, I took the sheetmetal off and cant decide how to open up the motor wire assembly however that works,, it just started to rain too awww geez, any one have a clue? Thanks for any tips you might have. .
  • James Crivellone
    Head Janitor
    • 6305
    just a heads up, if your sunroof rails are in fact shot I have a spare set
    i'm local too
    by rails I mean the slider assemblies, and the brass plate that secures to the crank/motor
    • elemental
      • Jan 2004
      • 112
      Well it took alot of fine tuning, but i was able to get it in the closed position and looking right.. just now its broken :? ow well next summer might have to fix it.. any one taken this assembly apart what dose the small sprialy wires turn around? ,, thanks
      • elemental
        • Jan 2004
        • 112
        Anyone Taken there front headliner out.? what dose the wires to push / pull the sunroof spool around? Someone knows.. thanks
        • chesster6969
          • 321
          THey dont spool around anything.
          They each get pushed into their own copper tube.
          You have a similar problem that happened to my sunroof. I had to replace the rails with the sunroof mounting points and the wires
