DOODS!
So my car usually runs at just under half temp after it gets warmed up, but last week she started run at a hair over the half temp mark unless I had the heat on. Today, I'm sitting in traffic and the temp just bounces (a couple times) from 1/3 to 2/3 on the gauge so I chuck the heater on to cool things down...which it does (to the half temp mark). I turned off the heat for a couple minutes and it did a couple more jumps so I got her home to check for leaks and I found nothing. I'll check the level after she cools down.
I'm thinking that this might caused by be air bubbles in the system?
Any Input would be greatly appreciated! The less time I spend messing around in the frozen dark ally...the better.
cheers,
Craig
cheers,
Craig
