analog clock wiring question
    i have decided to switch my broken obc out for the analog clock. there are 4 pins on the back of the clock and a bunch of wires to the obc plug. the guy i purchased it from failed to send me the clock plug, so what pin does what? from left to right they are numbered 30
    319
    31
    58k
    i'm pretty good with electrical so no one really has to go out of their way with wire colors and such. thanks in advance.
    Find an early 318 in a junk yard and clip the harness. Then just match wire colors.
    Originally posted by Gruelius
      ok thanks.
        well i checked 7 junk yards within 45 minutes of my house and none of them have one. anyone here have the plug they would be willing to part with? if so let me know the price and i will gladly pay it as long as it's not ridiculous. or back to the first question about the pin assignments.
          Contact Greg (M-Technik-3), and he might have some.
          Also, try searching for 'analog clock' and see if there are previous threads about hooking one up (I might have posted some information before about it... I can't remember which forum it might have been).
            Re: analog clock wiring question
            Sorry to bring back an old thread, but does anybody know the answer to this question? I am trying to wire up my analog clock, and I found the power, ground, and the illumination wires, in the harness to the old OBC, but I don't know which wires to connect them to on the analog clock connector. I've searched, but have not found any helpful info. All I've found is people saying to match colors (only two colors accually match). So, does anybody have an answer to the below question, or have any helpful tips?
            30
            319
            31
            58k
              30
              319
              31
              58k
              Those are Bosch nrs normally
              and if IIRC
              it's :
              30 : +
              31g : mass for light
              31 : mass
              58k: clusterlight (k= kombiinstrument)
              Maybe somebody chime in to confirm my answer
              1989 E30 318iS_______________________________1989 E30 325iC M-Technic I
              1997 E36 328iT
              1990 E30 325iT 24v SOLD
              1989 E30 325i 2.7i M-Technic II SOLD
                and if IIRC
                it's :
                30 : +
                31 : mass
                Thank you. what is "mass" though? Does it meen it "ground"? So, I have a power wire (30), ground wire (31), power for the light (58k), and ground for light (31g). Is this correct, or did I interpret it wrong? Thank you for the info.
                  Yup right :up:
                  Here I've some of the most common bosch ECE numbers
                  30 : + (permanently batt)
                  31 : Ground
                  58 : rearlights / cluster / citylights etc.
                  56 : Front lights (general)
                  56a : Low beam
                  56b : High beam
                  49 : Input turnsignal relay
                  49a : Output turnsignal relay
                  C : Cluster light turnsignal
                  54 : Brakelight
                  53 : Wipers
                  15 : + (key)
                  1 : Coil - immobilizer
                  4 : High Tension output Coil
                  50 : Relay starter
                  85 : Output remote relay
                  86 : Input remote relay
                  87 : main connection relay (disconnect if powered)
                  88 : main connection relay ( connect if powered ) :idea:
                  1997 E36 328iT
                    Yup right :up:
                    31 : Ground
                    56a : Low beam
                    56b : High beam
                    54 : Brakelight
                    53 : Wipers
                    15 : + (key)
                    50 : Relay starter
                    Cool. Thanks man!
