easy one probably!
  • el_4ever
    • 145
    easy one probably!
    how do you remove the stock gas pedal from the bottom of the car...
  • Jordan
    • 12916
    Pull really fucking hard, and hope it doesnt break.
    There is no easy way if the carpet is in. It has little clips that clip into a slot in the floor, and there is no way to poke them in with the carpet in the way.
    https://mtechniqueabs.com/
    • el_4ever
      • 145
      OK!!!! :!: :!: I pulled the carpet out and i had some dry mud it seemed, no rust apparently so I'm good on that...cleaned it out pretty good and felt around (had bad lighting) but did't see any tabs or any other fastener...can't really look at it until the weekend. I saw three little slots on the front but I stuck a little flathead screw driver and nothing...we'll see
      • spencers
        • Jan 2004
        • 1150
        What's wrong with the pedal?
        • el_4ever
          • 145
          it snapped just above the clip that Jordan talks about...i was going to replace it any way
          • 808BMW
            • 2910
            So you have to pull the carpet out to put a new pedal in?
            Just broke mine the other night, gotta get a new one.
            • el_4ever
              • 145
              it really sucks man...i think i'll have to pull the dremel out.. :idea:
              • Bimmerfanatik
                • May 2004
                • 5349
                Any more on this? Got the car with no pedal in it - just an aftermarket cover zip tied to the throttle lever. REALLY don't feel like pulling the carpet.
                • lordofmpower
                  • 153
                  Damn guys whats up with the rash of broken pedal's "stompin it" doesn't mean you actually have to stomp it ;)
                  • nickmp0wer
                    • 1427
                    you dont have to pull any carpet. Just rip out the broken one who cares if you break and the other one clips in
                    • Bimmerfanatik
                      • May 2004
                      • 5349
