Electrical Problem
  • bmp
    • Jan 2005
    • 81
    Electrical Problem
    I was replacing my heater panel and everything was working properly yesterday however today was a different story. The heater controls work but the window's, instrument panel lights (the check lights work), cigarette ligther, and the heater panel lights no longer work.
    Is there a fuse that goes with all these controls? Thanks.
  • Kilomph
    • Oct 2004
    • 599
    http://www.amazon.com/BMW-E30-Servic...1017397&sr=1-1
    • bmp
      • Jan 2005
      • 81
      Umm... yes thank you but how about some immediate assistance.
        Pull and check each fuse with an ohmmeter and replace any that show an open circuit. Then figure out what you did that might cause a fuse to blow. And if you don't find a blown fuse, re-check all connections.
        • gearheadE30
          • Jun 2007
          • 3734
          Well, you can usually tell just by looking if the fuse is blown.
          Google "BMW e30 fusebox diagram." its out there somewhere; I've used it multiple times before I got my bently.
          Project M42 Turbo
          • bmp
            • Jan 2005
            • 81
            I checked the fuse and looks ok but will change it anyways. In most cases what would be the cause of this? Any ideas greatly appreciated
