idle issue. Kind of odd one. 318is m42
  • rallyegolf
    • May 2008
    • 96
    I dont drive the car much, and when I started it up the other day, it had a rough start. No big deal, I ran it and it cleared up.
    Today on the way to work I pull up to a stop light and it sputters, shakes and dies. I tried to start it and it would fire up, but then die again. In a panic to get out of the intersection, I turned it over, gave it some gas, and it runs fine.
    I continued to work, and pulled into my parking spot where I let it idle, and every 5 or so seconds, my MPG gauge shoots all the way up and the rpm's drop. The car almost dies at that point, then corrects itself. In another 5 seconds it does it again.
    Ohh and when the car is cruising down the road, I have no problems at all.
    maybe a bad injector? maybe a vaccume leak?
    I guess I need a list of things to check so I can solve this issue. Thanks for any suggestions in advance.
  • James Crivellone
    Head Janitor
    • 6304
    I'd start checking that rats nest under the upper intake manifold and see what you find.. I fixed 99% of my roomates idle issues on his M42 just by replacing a few cracked hoses under there.
    • rallyegolf
      • May 2008
      • 96
      I started reading some old posts and I think that is what I will do after work today. I may eliminate all that crap and see if that helps. anyone have a good post on the removal of all that crap?
      • Teaguer
        • Sep 2004
        • 6167
        Yeah I second the maze of vacuum lines under the intake .
        Check out m42club.com for a few threads on eliminating that crap, if you are feeling adventurous go ahead and eliminate the throttle body heater set-up while you are at it .
        • rallyegolf
          • May 2008
          • 96
          Well a little update:
          I decided to take the car home on my lunch break and just ride my Motorcycle back to work. I got all the way into my garage, and it died again. There was a whole lot of shaking and clunking around, and now it will turn over but not start. I think something internally is out of wak. I did have time to look at the hoses under the intake manifold and everything looked pretty good.
          How can I test spark on a motor that wont start? Also I need to get my hands on a repair guide. What is the best one out there?
          thanks
          • rallyegolf
            • May 2008
            • 96
            New update:
            I got home from work and tried to turn it over to see what was going on and when i try to turn it over it goes.
            turn,turn,turn,turn,turn,turn,turn,turn,turn, clunk
            I think my motor is jacked. i am going to have to pull off the timing cover and see whats going on in there first. What a pain in the ass.
            if anyone is looking for a deal on a clean non-running 318is. let me know.
            • RedHoodRidah
              • Feb 2006
              • 1096
              Alot of crank but no start threads lately. If you look at a few of the other threads for the crank but no start issue you should look into them. Did you check fuel pressure?
              Did you have a loud fuel pump prior to this issue starting? It can be a few other things.
              92 Granite Silver Vert
              M60B40 5spd
              • gearheadE30
                • Jun 2007
                • 3734
                I think your engine is probably fine. As a wild guess without seeing the car it might be crank or cam sensor, a bad ground, something shorted in the injector harness, etc. If the MPG gauge is moving, it is injector related. To check for spark, pull the leads off one at a time and use a spare spark plug. You will be able to see the spark when the motor is cranked. Be very very verrrryyyy careful with this though; that is pretty high-voltage stuff.
                Project M42 Turbo
                • rallyegolf
                  • May 2008
                  • 96
                  This makes me feel a little better about it. I really didn't want to tear down the motor. I will go through the electrical and see if I can find the problem.
                  thanks again.
                  • rallyegolf
                    • May 2008
                    • 96
                    Dang, those sensors are kind of pricey.
