differential leaking
  • jrobie79
    • Mar 2006
    • 2523
    the differential on my car seems to be leaking, but it seems to be from the drain and fill plugs... how can i seal those up better so it doesnt leak? teflon tape or some other sort of washer or o-ring combo? or jsut get new drain and fill bolts? thanks
    1991 318i ---- 308K - retired
  • PУCCKAЯ_e30ka
    • Jan 2006
    • 1226
    new bolts would prolly be the easiest!
    • ethirtydavid
      • Jan 2008
      • 2331
      maybe buy a rubber washer...
      drain diff into something so you can re-use fluids if it is fresh.
      bolt - rubber washer... you get the idea..
      • kamotors
        • Nov 2007
        • 7102
        my old diff did that i just replaced the washer and bolt. the old washer seemed a little tweaked and i guess even the smallest amount can make it leak.
        7speedshop.com
        • ethree
          • Aug 2007
          • 1213
          You are supposed to replace cruch washers everytime you remove the bolt, though I rarely do and rarely have leaky shit like that. I had an audi with banjo fittings all over the turbo system and those loved to leak if the crush washer wasn't replaced.
          • jrobie79
            • Mar 2006
            • 2523
            yeah i figured as much, with the washer and all, it never really leaked before, but i went over to synthetic redline and noticed it more. will be doing this tomorrow or sunday
