CAI progress.
  • Jordan
    • 12913
    CAI progress.
    Found some time today, finished shaping the tubing and got it coated up with krinkle finish. The setup uses a K&N RU-2820 universal 3in inlet air filter. Pipe is full 3in into a billet aluminum afm adapter with a smooth transition to the square afm inlet. 95% of the adapters you see on ebay have no transition, just a wall.
    I started cutting out a cardboard template for the heat shield today. Hopefully I can finish that tomorrow. It will be WELL shielded from the engine temps where it is, plus the heatshield will also do its thing.
    Doesn't really sound much different then my previous stock airbox (drilled) with a K&N panel filter at low rpms. If anything its slightly louder and deeper. Boy does it roar over 4k though.
    https://mtechniqueabs.com/
  • DanGillan
    • Mar 2004
    • 4061
    so what's the difference between your adapter and shitty ebay ones? i didnt quite get it.
    Dan
    • slammed_e30
      • 514
      Looks good, my I ask how you bent the pipe? And the flat K&N filter for sale?
      Originally Posted by Rob
      fucking hell, your car is cleaner in the damn snow than mine ever has been in perfect weather. sedans own me.
      • Jordan
        • 12913
        The ebay adapters are a square sheet of metal, with a square cutout for the afm inlet. Welded to that flat plate is a 3inch cylinder. No internal transition, makes for extremely turbulant air.
        My adapter is billet aluminum, and has a smooth cnc machined transition from a 3in circle to a 2x2in square. Beyond that I ported and polished the adpater for maximum smooth flow.
        • Jordan
          • 12913
          I didn't bend the pipe. I bought a 90º bend from a local parts shop and cut it to my application. The K&N panel filter sold a couple days ago in the FS+WTB forum.
          • 318driver
            • 1714
            Looks pretty good. Do you plan on doing an MAF by any chance?
            90 325is
            IE stage 3s and refeshed m20....
            • kencopperwheat
              King of Kegstands
              • 14396
              YOUz needss a heatshieldz!!!11!
              On a more serious note, it looks damn good.
              Originally posted by Gruelius
              • Jordan
                • 12913
                No, I don't. I don't plan on spending any more money on m20 specific parts because m20's aren't where its at.
                A 24v solution is in my future, not sure when though.
                • 318driver
                  • 1714
                  :twisted:
                  90 325is
                  • M-technik-3
                    • 18946
                    Where is your radiator shroud? It channels the air mor efficently.
                    • Jordan
                      • 12913
                      It broke. I run at 1/4 temp anyways, I'm not worries about channeling air through the radiator. I don't want to run any cooler.
                      • diegom6
                        • 4447
                        and where are the back plastic cover protector of the beams?
                        Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
                        • 808BMW
                          • 2910
                          Removed for FURACE effect. (Somehow I don't think Diego will get it)
                          • e30Matt
                            • 5077
                            You mean FUH RAAAAAAZE?
                            • diegom6
                              • 4447
                              hehehe, I'm trying... :P
