Is it possible to bench test a starter? If so, how? And are there any safety precautions? This is a late-model starter btw.
Bench Test a Starter?
If you just mean check it to see if it spins, then all you have to do is hook it to a battery and give power to the solenoid.Comment
The "big" terminal(a M8 bolt) is continious +12v, use thick cable, or it will melt.
The bigger of the small terminals is the switched +12 through the ignition lock, that +12 engages the solenoid and makes it spin.
USE THICK WIRES FOR CONTINIUOS +12V AND GROUND OR THEY WILL GET VERY HOT, they will melt and cause burn if you touch them.Current:
BMW 320i 2d 2.0 m20 -88
BMW 325i Cabriolet 2.5 m50 -88
BMW 316i touring 1.6 m40 -90
BMW 320i 4d 2,2 m54 -01Comment
If there is no load on the starter, it won't draw THAT much amperage. Don't use small wire, but you don't have to use 00 gauge or anything.Comment
