Wheel Stuck to Steering Column
  • hamann318is
    • 3382
    I got my Mtech 1 today, and am removing the SRS bag. So I mounted the MT1 wheel with a inverted collar and rubber oring on the steering column, and then the stock washer, rubber oring, and 3 washers inside the wheel. I torqued that down to 60 ft/lbs. Decided I didn't like that setup (and hear I don't need that many spacers installed). Untorqued, and suprise, I can't get the wheel off. I can push it down, wobble it side to side, but basically it acts like the nut is still there, and won't budge.
    Before you even ask, the key is in and at On. I really need some help this time, and yes I'm stupid for putting all this stuff on it.
    The BMW 318 is back. With a vengeance.
