dies in neutral at stop light
    So this shit just started today. I had trouble starting the car this morning since the temp is like -100 outside. the check engine light comes on when I'm trying to keep the idle up to warm the engine. I still have 20w-50 so I thought it might b/c its too thick. Now the car would start fine but kindof buck if I accelerate too fast and die if I'm let the revs down in neutral.
    New alt recently
    New batt recently
    The first thing I'd suspect would be an intake leak.
      New alt recently
      New batt recently
      Check your fuel pressure. This is what happened to me before my fuel pump kicked the bucket. Mine would produce the proper amount of pressure or about 10 psi, alternately, until it died for good.
      My fast says: traction control is for the faint of heart :evil:
        Does it get better when it warms up? is so its a vac leak most likely.
        97 tacoma 5 spd 4 cylinder
        2001 330ci 5 speed
        83 733i 5 speed, (FS)
