Fuel Pressure??
  • brodee
    • Jan 2004
    • 2914
    Fuel Pressure??
    Anyone know what fuel pressure they are running? I'm getting ready to throw a gauge on and want to bump up the regulator a few psi since I'm running so lean. Just curious if anyone is running a gauge or knows their fp?
    "Modern cars may be able to outgun it, but few can match its character, its motorsport spirit, and the way it plasters a huge grin on your face at any speed." - Patrick George
    1988 M3 - Track Rat
    1989 325iC M50 Vert
    1989 325i Coupe
    1991 318is
    1995 318ti Club Sport
    2006 330i e90
    2008 Tundra Crewmax
  • rs4pro3
    • 5808
    I'm running 38psi right now with my mustang 19lb injectors on an 88 325is engine.
    85 325e 2.7 ITB'd stroker
    • brodee
      • Jan 2004
      • 2914
      Thanks, that helps a lot since I'm putting in some 19# mustang injectors I just got. Curious to get the gauge on there and see what it's at now.
      1988 M3 - Track Rat
      1989 325iC M50 Vert
      1989 325i Coupe
      1991 318is
      2006 330i e90
      2008 Tundra Crewmax
      • SpeedDemon_e30
        • Sep 2004
        • 48
        hey lets try 200lbs man lol
        • brodee
          • Jan 2004
          • 2914
          Sure Chris, we'll test it on your car first ;)
          1988 M3 - Track Rat
          1989 325iC M50 Vert
          1989 325i Coupe
          1991 318is
          2006 330i e90
          2008 Tundra Crewmax
          • brodee
            • Jan 2004
            • 2914
            I put the gauge on it and it was running 46 lbs. I bumped it up to 51 lbs and took it out and drove it for a while. It used to drop off around 6k rpm and now it pulls hard through 6600.
            I'll get the bigger injectors in and give them time to adjust and then get it back on the dyno and see if the problem is solved.
            1988 M3 - Track Rat
            1989 325iC M50 Vert
            1989 325i Coupe
            1991 318is
            2006 330i e90
            2008 Tundra Crewmax
            • e30evolution
              West Werks
              • 1888
              thats more pressure than you need.... what other mods do you have?
              http://www.westwerksauto.com
              • brodee
                • Jan 2004
                • 2914
                Dinan chip, 272 cam, headers, full custom 2.5" exhaust, K&N intake.
                I'm guessing my injectors are so plugged up there isn't much getting through. When I change out to the 19#'ers I'll kick the pressure way down and start adjusting it from there. At least with the gauge on it now I can adjust it between dyno runs and watch the AF ratio.
                1988 M3 - Track Rat
                1989 325iC M50 Vert
                1989 325i Coupe
                1991 318is
                2006 330i e90
                2008 Tundra Crewmax
                • kylebes1
                  • May 2004
                  • 2804
                  I like the car in your sig, give it to me.
                  51 psi is alot. i would be sure to turn it back down around 38 when you install the new injectors
                  • brodee
                    • Jan 2004
                    • 2914
                    I'll give you the black one, it's for sale :)
                    1988 M3 - Track Rat
                    1989 325iC M50 Vert
                    1989 325i Coupe
                    1991 318is
                    2006 330i e90
                    2008 Tundra Crewmax
                    • kylebes1
                      • May 2004
                      • 2804
                      two doors more than I really want
                      I was looking for a shell to put my engine in, but I think mine will work out and eventually be unique.
                      • skat 325is
                        • 296
                        Mines about 35psi idle...and 100+ when i hit 9psi 8)
                        yeah i know i gotta turn it down a little bit.
