Theromostat Housing/Gasket
    when replacing the gasket can you attach as is or do you need to put sometype of silicone sealant between gasket, housing and engine block??
    No sealant. Just make 100% sure the surfaces are clean and it'll be fine with that thick paper gasket.
    Adam Fogg- '88 M3
    Common sense- It's the new 'gifted'
