question about battery wires
  • mentaleeill
    • 850
    from the positive side of the battery 2 wires go to the front of the car, a 0-2 gauge and a 10 gauge. well the smaller one has no voltage at it on my car and there is no continuity between the 2 ends. is there a relay or fusible link in line somewhere?
  • Rigmaster
    • 3464
    Re: question about battery wires
    Nope, should be +/- battery voltage at the firewall end- and there should be continuity. Sounds like yours might be broken??
    Bret.
    • demlotcrew
      • May 2004
      • 297
      was the engine running when you did the test?
      Andrew AT E30zone.co.uk | H23-is | S14
      • Jordan
        • 12916
        Yes there is a fusable link in that smaller wire. Its located about 1.5ft from the battery. Give or take a bit.
        https://mtechniqueabs.com/
