Fan Shroud....is it really needed??
  • sparticus
    • Jun 2004
    • 64
    1991 318is
    Is the fan shroud really needed???
  • Jordan
    • 12916
    No.
    https://mtechniqueabs.com/
      • 37833
      Unless you have some issues with your cooling system you're trying to hide by putting the fan shroud on, no, it's not needed.
      Grover Beach, California
      BimmerHeads.com
      • Rob
        • 8166
        if you're running a low temp thermostat, no. I'm pulling mine off for the winter
        BEERTECH
        • boom-monkey
          • 1104
          It may also depend on your climate. I know that down here in Florida in the summer months it is a definate improvement. I went from running at 3/4 up the temp gauge at stop lights to less than 1/2 while sitting. So from my experience it is a definate improvement over nothing. Plus I think it cleans up the look of the engine bay and so I can't see any reason why someone wouldn't run one.
          • Rob
            • 8166
            My car runs at a max of 1/4 on the temp gauge in the summer, hence why I'm removing my shroud for the winter
            BEERTECH
            • demlotcrew
              • May 2004
              • 297
              well there’s something wrong if it runs at 1/4. it should be 1/2 min! i would say that your thermostat needs changing, and im sure your fuel efficiency will go up too.
              Andrew AT E30zone.co.uk | H23-is | S14
              • Rob
                • 8166
                lower temp thermostat and 30mpg, no complaints from me.
                BEERTECH
                • demlotcrew
                  • May 2004
                  • 297
                  That does not make sense, a lower temp thermo wont cool the car down by a whole 1/4 on the temp gauge. Anyway im only telling you how its meant to be, you are under no obligation to listen to me, but i would not run my car at such a low temp.
