so im driving and my wheels start to shake a bit becuase they are not balanced.... now they are though.... and my anti lock brake light comes on..... i take off the wheells move around the wires that connect to the caliper..... and the light goes away when i turn the car on again..... a day later my brake lights go out..... i change all the bulbs but when i press the brakes the lights dont come on..... and then today i notice my crusie control aint working...... anybody know what it could be.... i think for the lights its my brake pedal switch wich im gonna change...
weird problem im having....
For the brakes, it is probably a loose connection or the sensor. It sounds like you have some corroded wires, so basically you need to track down the breaks and everything should be dandy. Easier said than done though, I had to run new wires from the fuse box to the washer pump because the break was somewhere in the harness.
Check your fuses.Erick Mahle | FullOpp Drift | YouTube
..::Support FullOpp::..
FullOpp Stickers for sale!
Feedback Thread
Originally posted by Mr. Anderson...one of the most hardcore E30's around. :D
