i used search. i did learn some stuff, but it didnt answer my questions, so here goes...
on my 87 325:
2 months ago, on the prev. owner's mechanic's advice, i topped off the non-converted, low ac with 2.5 cans of "freeze 12". the mechanic had added freeze 12 to the car before, so it probably had a mix of that and maybe some r12. it cooled to 70 degrees at the vent in 85 degree weather. the slow leak was faster than i expected and the refrigerant was mostly gone in a month.
so, about a month ago, i pulled a vacuum pump on the low side, pulling 30 pounds for 30 minutes (car not running). i then added 1 can of 12 oz 134a with 4 oz lube and leak sealer from a conversion kit. the pressures read 40psi low and 200psi on the high side. (1) how did i get that kind of pressure with that little refrigerant? i didnt add any more than that one can because the pressures were good. it cooled slightly better than with the freeze 12, i think.
this weekend, it was down to 5psi on the low side, so i added another can 134a/oil/leak sealer. got me to 35-40 low and 200 psi high.
my pressures look pretty good, a little high on both sides if anything, right? so (2) I can't figure out why my air isn't frostier.
3) my compressor does not appear to be cycling, just running nonstop when the AC is on. why? is this b/c there isnt enough freon in it?
4) I am going to have to do something about the leak... i will soon be adding a 4-oz can of sealer with dye, to hopefully at least help me find it. what are common locations for leaks?
5) AFAIK, the system had not been opened, but it has been run "low" for sure. and i'm not totally happy with the cooling. do i need to replace the dryer? the expansion valve? the seals? (hopefully not) the compressor?
(6) EXTRA CREDIT: when you stop the car, the compressor continues to spin for a good 10+ seconds... in the opposite direction of its usual rotation. i guess the pressure in the high side is trying to get to the low side... but has anyone heard of this? shouldn't the pressure equalize by going through the other way, instead of exerting so much force as to turn the compressor? i'll check soon and see if it is just the clutch moving, or the clutch and the pulley (meaning stuck clutch, explaining the non-cycling).
thanks for any and all help,
evan
on my 87 325:
evan
