E36 Muffler on E30
  • qimis
    • Mar 2004
    • 279
    Originally posted by C ///M
    It fits, however since you have a specifc muffler tip cut-out, that's what makes it trickier. The job would be much easier assuming you are going to bolt the muffler to a Factory e36 center section. You will also have to cut the tips off the muffler and remount them at the correct angle (because you will be mounting the muffler so it sits a little different compared to the e36.
    Any, my advice would be to NOT use a factory e36 m3 muffler on the e30. Reason being, I have a '95 M3 center section and a '97 M3 rear muffer (all e36 m3 rear mufflers teh same). I did a test fit and it's not for the faint of heart, especially when having a specific muffler tip cut-out (might be easier for you depending on the M-tech II rear tip cut-out). I am selling my E36 M3 rear muffler and picking up an AA E36 M3 rear muffler to mate to the E36 center section because it is smaller, not to mention the standard m3 muffler weighs 47lbs with cat-back pipes.
    Summary: the stock m3 muffler is really big, too big for the e30. It is going to be more of a headache than you think but will work if you're adamant about doing it.
    great info ! thank you ...
    i'm might be going for a breyton muffler off 325.
