ok what the hell is there a way to remove the hook shaped plug on top of the b pillar without breaking the b pillar? which way does this thing even come out?
Rear Pop-Out Window Removal
Tags: None
Re: Rear Pop-Out Window Removal
Step 1- take a prozacOriginally posted by DSchultz325eok what the hell is there a way to remove the hook shaped plug on top of the b pillar without breaking the b pillar? which way does this thing even come out?
Step 2- remove the phillips head screw from the hook
Step 3- tilt the hook UP (push the tip of the hook towards the B pillar) and pull the plastic hook out- it's probably stuck a bit to the vinyl- but it will come out
Step 4- done.
Bret. -
hah i posted that right after i worked on it for like 10 minutes. thanks.I retired my E30 for now...
E46 323i
David SchultzComment
