i have a msd 6 btm and i was testing if it works every time i jump the two wires that msd say to test if the box is working the ABS motor turns on yes the ABS i dunno crazy stuff :o has this happen to anyone? any thing i should look at? thanks
msd 6btm in a m20b25 turbo e30
:roll: informativeOriginally posted by mattdollars to donuts you dont have it hooked up right.
Matt
I would go back and double check to ensure you have connected the correct wires and terminals. BMW's wire color codes can be tricky. A Red with brown stripe can easily look similar to a Brown with Red Stripe.
Best of luck.Below the radar...Comment
