How do i change a in bowel oil filter on 318is ?
  • mjc85
    • Mar 2004
    • 164
    I've read bpurcells thing on his site but where the hell is this 13mm hex that i need to remove so i can change the oil filter ?
    Mitch
    1990 318is Brilliantrot
  • e9nine
    • 1890
    Do you have an M42?
    I don't quite understand your question but you seem to want to change your oil.
    If you see the canister which I think you are referring to as bowel, you will see the nut.
    If you buy the oil filter kit, you will see there are gaskets and washers in it for the
    canister, rod and oil pan bolt.
    good luck
    edit---- here is a pic of the canister, it btwn the AFM and block
    • mjc85
      • Mar 2004
      • 164
      Yes i need to change my oil and oil filter, so the filter is inside that weird looking canister ? I have never changed the oil on my car yet and have done to other cars and i'm use the the normal oil filter on the side of the block.
      • mjc85
        • Mar 2004
        • 164
        Also do i need to torque the oil drain bolt at all ? or just the oil filter canister bolt ?
        • ///M42 sport
          • 3952
          just hand tighten it, but not too tight. The filter is just a drop in. Very easy to do.
          Oh yeah, change the gaskets that come with the filter.
          • mjc85
            • Mar 2004
            • 164
            I didnt get any gaskets, only got an o-ring seal.
            • ///M42 sport
              • 3952
              sorry I meant o-rings and washers
              • mjc85
                • Mar 2004
                • 164
                Yeh i've done it, the washers are a part of the filter, they are joined on top and bottom.
