Motor Mount ?
    Motor Mount ?
    Well at my first autocross ever ( 8) and the best driving experience iv'e had so far),
    After our 4 runs we get to go for fun runs. I told myself ok , last one then i have to get home.
    After a slalom i take a turn and understeer almsot into a cone :S , and after i come out of the turn, i have a crazy vibration in my steering, actually, the entire car.
    So i pull into a parking space and my car is idling like a vibrator on wheels. It isnt like a rough idle, my idle is fine, but my mirrors are shaking so quick that i can barely see out of them.
    I take a look and what do i see.......
    My questions are:
    -Is this an easy fix it yourself?
    -going to be pricey?
    -any part #'s of the things i need to replace?
    ANY input would be greatly apreciated
    Max is 18 a side and it's an at home fix for mechanical inclined.
      Ok for anyone who ever is in need of thsi thread in the future, i found this article at good ol' pelicanparts
      Are you feeling a weird vibration from your car when you shift or accelerate? Is the shifter rocking back and forth like it's possessed? Are you hearing and feeling a huge knocking noise when you drive?
      good walkthrough of how to do it
      looks like a peice of cake :)
        heh thats easy.
        i've broken both my mounts and one trans mount with some spirted driving ;)
        Cam .W '91 325is
        Spaz's 1991 Alpine White???? S52 Build Thread...
          Little tip for the 318ers (without looking at the article).
          Undo the bottom bolt for the shock absorber on the passenger side of the engine (goes from the engine to the subframe). It is a royal PITA to get the motor mount if that bastard is still attached.
            Replacing Trans & Motor mounts is easy, and there is no reason not to get the poly IE motor ($30) and trans ($35) mounts.
            07 335xi Sport
            00 S2k
            01 A4 1.8t-Sold
            88 M3-Sold
            91 325iC-Totaled
            89 325iS - Sold
            87 325-Totaled
              Thanks for the heads up :up:
