Convertible guys I need Help
  • Oodles-of-Noodles
    • Jan 2009
    • 188
    I am doing a manual top conversion on my vert and I would like to know if there is a way to just activate the tourneu cover motor so I can fold the top manually then push the button to lock it down?
    I have searched online but only have seen fixes for the main electric motor or a full manual conversion.
    1993 Alpinewiess Vert - Sold
    1992 Alpinewiess Vert - Sold
    1990 Lachsilber IX - Sold
    1990 Calypsorot Vert - Sold
    2005 Blue Saab 92-X - DD
  • jw 325ic
    • Sep 2006
    • 1360
    youre gonna have a manual top and youre too lazy to push down on the cover? ugh...if you have the motor you can wire it up to a switch on the dash facia or rear console.
    • Stevie30
      • Apr 2007
      • 1534
      Oodles, Disconnect the rod that raises and lowers the cover. You can now jog the top up/top down button to latch and unlatch cover. Now you can raise and lower the cover manually. I am assuming you have already disconnected the rods for the top and back flap. All the electrical on both motors will need to be connected in order for cover latch to work. Good luck.
      1991 325ic and 1991 318is
      • Oodles-of-Noodles
        • Jan 2009
        • 188
        All the rods have been removed but the I need the wiring diagram so I can actuvate teh cover motor to pull the two steel cables taught to close the cover. How do I do this?
        • Oodles-of-Noodles
          • Jan 2009
          • 188
          I do not have a latch like the real manual top.
