Uneven rear ride height!!
  • Wes325
    • 563
    Well......... this sucks! My left rear fender looked to sit a little bit lower on the tire than the right did so I decided to measure it. Not to my surprise I saw that the rear left side sits a half to 3/4 of an inch lower than the right side. I replaced the rear shock mounts with the ones from Ground Control and that was obviously not the solution. I also observed a low creaking noise coming from the rear when going around sharp turns. I am stumped on this one and I really need some help.
    ________
    AR50
    - 318is 4 life
  • UNHCLL
    • 8790
    Check to make sure your springs are lined up correctly on the pads.
    Below the radar...
    • franz
      • 631
      Broken sway bar mount?
