Car takes a while to start up on warm/hot days - Any ideas?
  • rasumadu
    • Jan 2009
    • 5
    Hey guys, new to this forum and I own a 1990 E30 318i...recently noticed that on warmer days the car takes longer to start up...specially when I go to work and leave it in an uncovered car park...once sat in it for literally half n hour constantly turning the key before it started up again
    I know its not a battery problem coz I had that replaced about 4 weeks ago so just wondering if anyone has any clues or has experienced anything similar? Cheers
  • Reign
    • Nov 2008
    • 125
    That right there makes it sound like a starter issue to me, but as always, a problem can't just be diagnosed like this. Make sure you get it checked out by a mechanic unless you're willing to replace the starter and find out for yourself.
    '91 318iS
    Koko's Garage - BMW and Mercedes Specialists
    651 Mount Auburn St, Cambridge, MA, 02138
    Selling This Car:
    http://r3vlimited.com/board/showthread.php?t=132392
    • dark_islight
      • Jun 2005
      • 41
      what does that mean?
      1. Does the starter engage and turn the engine over (crank over)?
      2. Does it just take longer to fire up (run)?
      Be more specific....."start up" is too ambiguous
      dark_islight
      _____________________________________________
      • rasumadu
        • Jan 2009
        • 5
        sorry...well i'd say that it's just taking longer to fire up but the engine definitely isn't turning over at the first turn of the key...starter seems fine to me but then again i'm no mechanic
        • Adrian_Visser
          • Jun 2006
          • 2823
          so you turn the key to the start position, is the starter making the starting sound you know "wa wa wa wa" or what ever. or does it do nothing when you turn the key. i.e silence
          '89 Alpine S52 with goodies
          • Spinning Tires
            • Feb 2007
            • 283
            If you dont know the difference between cranking over and not cranking over. Go see a mechanic
            First: 1984 318i
            Second: 1987 325
            Third: 1987 325is
            Current: 1990 325i (Soon To Be 335i)
            • rasumadu
              • Jan 2009
              • 5
              does nothing when u turn the key...but i've pinpointed it to do with the ignition barrel getting hot and most likely heating the wiring inside...it was really hot yesterday and took around an hour to get it going...managed to keep it relatively cooler today using sun shades and started without hesitation
