Water Leak, help.
  • Holland
    • Nov 2008
    • 7212
    Water Leak, help.
    I'm having an issue, there is moisture condensation in my trunk. I'm quite perplexed on how it gets there though. The trunk seal is good, the taillight seals seem good. when I spray the car with water around the trunk, under the car, and in the wheel arches I get nothing. Only when I drive in bad weather do I get water in the trunk. It collects in the lower bins in the sides but the heat evaporates it and it ends up collecting on the top and in my taillights. anyone familiar with this issue?
    Originally posted by DEV0 E30
  • ethree
    • Aug 2007
    • 1216
    Clogged sunroof drains. Do a search you'll find a lot of info on them.
    • mikeedler
      • 6707
      taillight seals-- replace them and the problem will be gone! how could it be the sunroof drain when it is when he is driving????
      • norcalE30
        • Dec 2008
        • 932
        ^^^ uh, because he just said it only happens in bad weather, i.e. when it rains. he said he sprayed water on the trunk, wheel arches, and underneath the car. not the sunroof
        Originally posted by kronus
        pff, all of you are slow as hell anyway. Eta > all
        • StereoInstaller1
          GAS
          • 22679
          Sunroof drains, antenna gromet, tail light gaskets, broken spot weld for the hinge mount, or the sneaky one...little plastic mounts for the "C" pillar covers.
          GL!
          Luke
          Closing SOON!
          Thanks for 10 years of fun!
