CEL Stomp Test = nonstop flashing?
  • T.Dot_E30
    • Mar 2004
    • 286
    My Check Engine Light came on.
    First thing i did was the pedal stomp test to get the code (Not the first time i've done this)
    CEL blinks once, pauses as normal.
    Then it just keeps flashing nonstop at the same pace, no pauses, no stopping, just constanting flashing.
    I thought werid, it can't get no codes from it, searched online, don't see any explaination for the constant flashes.
    Anyone know what could be wrong?
    Car seems to drive like normal, fuel consumption seems normal. Tried it several times and got the same results.
    TIA.
    Trevor
  • lordofthewaters
    • Oct 2005
    • 714
    Try disconnecting your battery, then see if you get the light again. Try the stomp test and see what happens.
    Sarcasm is a body's natural defense against stupid.
    When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
    "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
    Old age and treachery will always overcome youth and skill.
    • T.Dot_E30
      • Mar 2004
      • 286
      Tried this, didn't work.
      CEL light came back on, stomp test provided same results.
      Cars still runs good, got better gas mileage on this tank than the last. (500+km) But that was probably due less traffic and more freeway driving.
      • SamE30e
        • Sep 2007
        • 4319
        Shot in the dark, TPS?
        If not, try swapping ECU's if you have another kicking around.
        1985 325e 2.8 Turbo VEMS
        • xLibelle
          • Aug 2004
          • 2673
          the manual states leave bat disconnected for 10 minutes *shrug*
          it also states to says if theres an error, replace dme.
          • T.Dot_E30
            • Mar 2004
            • 286
            Which manual? Bently? Isn't there a code for bad dme?
            I'd swap ECU's and TPS(Pain in the ass since the little torx bolts are siezed). I also want to try swapping the AFM, i have a few others laying around.
            But I hate working outside in the cold.....
            Today should be warmer, ill try it after work.
