strut tower crack (strut mount ring)
  • guibo09
    • Dec 2008
    • 834
    i found 2 cracks on the strut tower ring driver's side. they are about the height of the ring, and are exactly aligned with the bolts for the strut mount.
    from searching, it seams like cracks are more common along the strut tower to body joint. this seems to be a different problem.
    anyone seen this before? can i just weld it up, slap on a strut bar and hope for the best?
    90 E30 325i
  • ethirtydavid
    • Jan 2008
    • 2331
    pictures = 1000 words
    • guibo09
      • Dec 2008
      • 834
      yeah, forgot to snap one off. coming tomorrow.
      90 E30 325i
      • Knockenwelle
        • Jul 2008
        • 395
        Dukes of Hazard?
        Mike
        '91 325i track car. Mostly...
        • gearheadE30
          • Jun 2007
          • 3734
          Strut towers front and rear are known to be a little bit crack-prone, especially when it comes to cars with stiff/low suspension that see a lot of use on bumpy roads. Usually there is rust and corrosion involved as well.
          Project M42 Turbo
          • guibo09
            • Dec 2008
            • 834
            there is some rust, but i think it came after the crack. the car has been on stock suspension all its life, and never tracked. maybe the potholes did it.
            ill have it rewelded. will a strut bar eliminate cracking problems even with stiff suspensions?
            90 E30 325i
            • guibo09
              • Dec 2008
              • 834
              pictures finally!
              90 E30 325i
              • AndrewBird
                The Mad Scientist
                • 11898
                I'm not really sue what would cause it to crack there. It's kind of a strange location. As minor as it is though, welding should fix the problems with no effects afterwards.
                • guibo09
                  • Dec 2008
                  • 834
                  yeah gonna have the body shop weld the two cracks.
                  90 E30 325i
                  • Liam
                    • 753
                    More common is just a bulging of the strut tower top and distortion of the inner side rail. This is actually semi common though on cars with stiff suspension and high mileage or have been driven aggressively.
                    I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
