I've attached pictures of said issues
My water pump went and I replaced it and now I have no heat...the system was bled a few times after the procedure....Today I checked all of the hoses and they're hot except for the hose leading to the top valve of the firewall going to the heater, the bottom one is hot
I've traced the top hose to the bottom of the thermostat housing and I've attached pictures
Its cold out here and I would very much like some heat, any help would be appreciated
Currently I am attempting to bleed the system....I got under and saw that the little blue bleeder valve is shot and I cannot turn it so I ran the car for 15-20m and took off the coolant reservoir cap and I am letting it sit for some time (it's ghetto but it's worked before)
Second I am confused as to where my bleeder hose should lead to...currently I have it just hanging and when it needs to the coolant bleeds on the tierods then onto the street
in the picture you can see how long my hose is
...should it go in one of the holes pictured?
