you will want to add new fuel hoses and fuel injector O rings to the list. Also replacing all the vacuum hoses and intake boot wouldnt be a bad idea either. why not an air filter too lol.
and this is why I posted this....air filter will be done as well, however I am getting a cone unit from a freind for free, so thats not costin me abnything
Originally posted by scott_is
maybe add some fluids? brake fluid, power steering, oil for engine+tranny+diff
Scott
all oils aren't listed but will be done, I'm currently looking up all the weights and preferred manufacturers
Originally posted by Jean
I see trailing arm bushings, but no sub-frame bushings?
How is the guibo & csb?
Is your shifter tight?
shifter is still being figured out. I'm probably going to be swapping it out for a z3 or z4 shifter for a "short throw" shifter. Thanks for the subframe bushings.
