Hey guys, I traded my old car for this 1984 318 E30, it has a complete M20 swap in it, but the guy didnt finish all of the wiring,
Everything else works, except the turn signals, and the tach / speedo / fuel gauge / pretty much nothing but the battery light works on the cluster.
I have been driving it around without those things not working, but im a gauge watcher, i want to see how much fuel i have and how fast im going / revving it up and any other needels / lights that pop up
I have picked up the Haynes Manual for the BMW 3 - 5 series it says that both models are covered there..
My question is...
Do all of the harnesses use the same colors for each specific thing? I.E. tach uses the same color on all harnesses? or the speedo?
The repair manual I have doesnt go into the specifics per model.. it just has the basic wiring diagrams, from the book all the wiring colors are the same. it doesnt have different layouts per vehicle... is that the case ?
I have the ECU pinout, but i was told that you cannot directly wire the Cluster from the wires coming from the ECU that you have to go from the wires coming out of the fusebox, so the ecu pinout doesnt seem to help me much... i had planned to go pin for pin and wire everything up,
The ECU is under the dash on the passenger side, it goes from there outside into the firewall/fusebox that is inside of the engine bay on the drivers side, then it comes down into the cabin, and its a big wad of wires tucked away under the dash there....
The Wiring from the Firewall forward is from the 325i, and the rest is the original body harness from the 318.
The original car is a 84 318i -
The swap came from a 89 325i.....
Info about the ECU/Engine-
325i
M20B25 (170hp)
87-91
Bosch Motronic M1.3 - 0 261 200 525
I have looked all over and found nothing but wiring info for other swaps and stuff, any info you can give me would be greatly appreciated!
My question is...
325i
M20B25 (170hp)
87-91
