Front strut replacement w/o removing hub
  • the bob
    • Aug 2004
    • 51
    Hello all,
    I am going to replace my front and rear shocks with bilstein tourings. I am wondering if anyone has had any success with removing the front strut without taking off the ball joints and caliper. My mechanic friend thinks we can just remove the three bolts holding the strut to the hub (he is a 70 year old german mechanic who owns his own shop)
    Has anyone had any success with this.
    It seems like It would make the job a bit easier than it sound with the removal of the entire hub
    If it is possible to do it that way what are the draw backs
    thanks alot
    I will let everyone know how it turns out
    bob
  • Stu Mc
    • 4083
    Unfortunately, no, not on standard 318/325 struts. The E30 M3, on the other hand, has 2 piece struts where dropping the ball-joints is not required.
    You'll have to drop the ball joints, you can read about a quick, easy way to do it here: http://www.r3vlimited.com/phpBB2/viewtopic.php?t=12248
    • the bob
      • Aug 2004
      • 51
      Thank you for your quick reply.
      I looks like it is all one piece.
      that sucks
      thanks
      bob
      • Nick325is
        • 1409
        If you are talking about changing the front shocks and springs without dropping the ball joints then yes it can be done. I did mine without taking anything off but the sway bar links and rotor and caliper.
        Nick
        • the bob
          • Aug 2004
          • 51
          that is what I am asking.
          Iis it possible. was there any tricks to it.
          Thanks for all the imput.
          bob
          • Stu Mc
            • 4083
            Nick
            :shock:
            Interesting. How is this done? Do you slide the strut tube through the hole in the shock tower? I suppose it is possible to compress the spring and put it all back together while on the car. Is getting the spring on over the newly installed strut difficult?
            Thanks,
            Stu
            • schnitzer teil-jäger
              • 661
              loosen sway bar mounts
              remove top 3 13mm bolts on top bearing
              compress spring with rod and shackle compressers
              push down on strut housing and pull top out
              it will barely clear the fender
              install new strut inserts and springs
              reasemble
              don't forget the sway bar link
              w
              i was robbed and they stole my sig...
              • Stu Mc
                • 4083
                Gotcha. Cool.
                • Nick325is
                  • 1409
                  Yeah, the whole thing barely cleared the fender to get it out and put it back in. But it did save me the effort of having to drop the ball joints.
                  Nick
                  • Stu Mc
                    • 4083
                    Had I not been swapping strut housings when I did me last spring/shock swap, I would have done it this way. Good info fellas.
                    • the bob
                      • Aug 2004
                      • 51
                      Hello all
                      and thanks for the imput.
                      I am going to try to do it today. we shall see how it goes
                      Is it easier just to remove the ball joint and control arm like it says in benlty or try it with the spring in the car. Which method is safer as I am aware that a loose spring can hurt
                      thanks again.
                      bob
                      • Nick325is
                        • 1409
                        If you try to do it with the spring in the car then be sure to use a good spring compressor so that you don't end up with springs flying everywhere.
                        Nick
                        • 65Matt
                          • 172
                          So - did anyone have success with this method?
                          • the bob
                            • Aug 2004
                            • 51
                            I just removed the whole hub like bently says.
                            I was not that hard and probably easier to compress the spring.
                            just be careful not to ruin the ball joints and tie rod ends like I did
                            that sucked
                            bob
                            • kencopperwheat
                              King of Kegstands
                              • 14396
                              how did you ruin them? you didnt use a picklefork did you? I use some older nuts and thread them on a little ways and then give them a good whack with a hammer - I've taken them out 4 times in the past 6 months and it's worked everytime.
                              Originally posted by Gruelius
