I need a favor
  • dvmotorsports
    • Apr 2008
    • 658
    I need a favor
    So my wife and I both have 318's. They are both lowered. What I need to know is what are the stock fender arch heights front and rear so that I may compensate for aiming the headlight as I just swapped both cars to smileys.
    If anyone has this info or can break out a tape measure and check for us, we would greatly appreciate it.
    J&K
    Originally posted by jrhaile
    For the record I have never fucked a goat.
  • gearheadE30
    • Jun 2007
    • 3734
    Compensation doesnt work like that, unless you want to calculate the angle change of the car from the rake. Just find a flat wall somewhere, park 20 feet away. Measure from the ground to the headlights and then measure on the wall so that the flat part of the cutoff is 2-4 inches lower. Its easy enough to do by eye.
    Project M42 Turbo
    • Adrian_Visser
      • Jun 2006
      • 2823
      that method isn't nearly as accurate as a proper aiming system , but if you're gunna do it that way so be it just make sure that the parking lot is dead flat too
      '89 Alpine S52 with goodies
      • dvmotorsports
        • Apr 2008
        • 658
        Yeah I know it doesn't work like that. That is why I wanted front and rear arch heights so that I can take the angle into consideration as well. I can't exactly recall what we did at the dealership when I was working there. I think it was 2'4" at 25ft. But like I said, i need to get heights to comp for the lowering because 2'4" would have the lights pointing upwards now.
        • dvmotorsports
          • Apr 2008
          • 658
          anyone?
          • dvmotorsports
            • Apr 2008
            • 658
            ttt
            • SpecM
              • Oct 2005
              • 4531
              are you serious? just get them close, like gearheadE30 said
              1989 cirrisblau-metallic 325i
              • dvmotorsports
                • Apr 2008
                • 658
                of course i am serious. if you see my build thread, you will see how anal i am.
