oil in coolant reservoir
    my coolant reservoir has oil, does this mean i have a blown head gasket? i'm pretty sure this is something major, how much does labor typically cost to have it fixed by a mechanic?
    thanks!
    Lael
    '88 Lachssilber ///M3
    '89 Zinnoberrot 325i
    '99 Orientblau 528iT
    If it is a manual transmission car, the oil can only come from a leaking head gasket. But if an auto, it could be transmission fluid from a leaking cooler (inside the radiator).
      Dude ... you've had an answer for almost everything. I'm gonna throw away my bentley and bombard you with questions from here on out :D
      Cheers
        the car is a manual trans. i'll replace the gaskets... Thanks!
        Lael
          bad news, dude...
          have the head itself checked out too, a cracked/warped head can go along with a head gasket failure
          1989 cirrisblau-metallic 325i
            mine cracked at the same time it blew. heads alone will run around $200 if wrecked..
