o2 sensor replace / engine oil check light
    one) what size socket/wrench is needed to replace o2 sensor......turns out my house is devoid of a tool that fits. and a special 02 socket is needed, or not?
    two) I've misplaced the owner manual I bought, and wanted to know what the "engine oil" check light means.....as I have enough oil in there.
    The engine oil check light is supposed to let you know when the engine oil level is low.
    If your oil is full, then there my be a problem with the sensor or wiring.
    And I believe the o2 sensor requires a 22 mm/ 7/8" wrench or special socket.
    You should be able to get a wrench on there, I can't really recall.
      thanks. I think the whole check panel is weird because the washer level sensor is bad.
      :up: thanks, I'll pick one up next time I'm in Sears.
