Alternator was replaced still wont keep charge
  • NewBMWguy
    • 2
    1984 bmw 318i Has had the alternator replaced and car still will not keep charge. What could be wrong did I get a faulty refurbashed alternator?
  • SpecM
    • Oct 2005
    • 4531
    possibly, but the battery could still be bad, or you could have some parasitic drain
    1989 cirrisblau-metallic 325i
    • hye d
      • Nov 2008
      • 34
      Hook up a voltmeter to battery , should get about 13.5 volts with engine running at 2000 rpm..
      • netcsk
        • Apr 2004
        • 1609
        Did you check that the alternator is grounded correctly? Check for continuity between the alternator body and the chassis of the car.
        • Spinning Tires
          • Feb 2007
          • 283
          A burnt out battery light bulb in your gauge cluster or a broken wire going to the battery light. It sounds stupid but its true
          First: 1984 318i
          Second: 1987 325
          Third: 1987 325is
          Current: 1990 325i (Soon To Be 335i)
          • everlast
            • Oct 2004
            • 225
            ^^ bingo.
            If the battery is known good (you could always pull it out and take it into a store, most load test batteries for free) then you need to do a test for parasitic drain.
            • xwill112x
              • Jan 2009
              • 4236
              clean your battery, if theres enough crud on top of it, it will drain it.
