OIL SLICK!!
  • kylebes1
    • May 2004
    • 2804
    OIL SLICK!!
    I cannot find a hole or even a crack in my oil pan, but when i had the front end in the air iol dripped from between the engine and trans.
    You think i just need a new pan gasket?
  • DaN
    • 1265
    Possible rear main seal leak, or pan gasket.
    Hard to tell without seeing it.
    • kylebes1
      • May 2004
      • 2804
      is it possible to remove the pan by only lifting the front end? I do not want to have to drop the subframe.
      If it is the rear main i am fucked
      • DaN
        • 1265
        You have to either remove the subframe, or unbolt the motor mounts and jack up the engine.
        Otherwise you won't clear the strainer on the pump.
        • kylebes1
          • May 2004
          • 2804
          you are right, forgot about that.
          • Jordan
            • 12907
            Rear main seal. Have fun.
            https://mtechniqueabs.com/
            • kylebes1
              • May 2004
              • 2804
              any writeps about removing the subframe?
              • DaN
                • 1265
                Just support the engine with a hoist or something, and remove all the bolts that hold it in....
                You won't have to remove the subframe to do the rear main seal....
                • kylebes1
                  • May 2004
                  • 2804
                  how many hours you think a rear seal would take to replace, it may be a job for a mechanic.
                  • Jordan
                    • 12907
                    Its about a 5 minute job when you had the engine out of the car. Its part of basic engine prep before tossing it in. The rear main seal is so cheap, I can't believe you didn't replace it then.
                    Only excuse I see is ignorance.
                    • kylebes1
                      • May 2004
                      • 2804
                      I am not ashamed,
                      But it really was, I should have replaced more shit like that, but I guessI get to do it now.
                      • NC325iC
                        • Mar 2004
                        • 6565
                        same deal with mine but its not rear main i believe mine is the oilpan gasket
                        but it only drips like 2 drips a day and i check the oil bout 2 times a week and it hasnt been low yet
                        • kylebes1
                          • May 2004
                          • 2804
                          i am gonna get mine fixed soon, it is parked for the moment, i am goign to get a new car as a daily driver, Japanese made though
                          • Spaz
                            Crazy Canuck
                            • 2276
                            all seals should be replace before a motor goes in imo.
                            Cam .W '91 325is
                            Spaz's 1991 Alpine White???? S52 Build Thread...
                            • kylebes1
                              • May 2004
                              • 2804
                              since my 84 body is such a POS and I have learned quite a bit, i am gonna redo the swap into a 87 es and do it right this time, since there will be no time issues
