FUEL INJECTOR cleaning
  • shields
    • Sep 2004
    • 46
    What's the best way of cleaning fuel injectors. Just pouring cleaner into the tank takes for ever and doesn't work too well. I've heard of kits that attach directly.
    Has anyone cleaned their injectors directly? if so, how?
    Thanks in advance...
  • cahomey
    • Mar 2004
    • 1201
    Sea Foam
    "It's like a koala bear crapped a rainbow in my brain."
    R.I.P. Harry Goz aka. Captain Murphy
    "My ride, My ride, she don't beg, steal, cheat, or lie,
    My ride, My ride, and our relationship is classified."
    • OldUser1
      • 636
      Originally posted by cahomey
      Sea Foam
      I swear by that stuff.
      -Kenyon
      • Jordan
        • 12916
        Have it done professionally. Also get the injectors flow matched to one another at the same time.
        Don't use fucking seafoam.
        https://mtechniqueabs.com/
        • DaN
          • 1265
          They make kits that have a small bottle of cleaner, which is presurized by compressed air.
          You pinch off the return line and run the engine off the cleaner until it's used up.
          This is what the professionals use, not sure if it's available from the auto parts store. Perhaps.
          • Purdue89E30
            • 991
            Use sea foam, it's a great time if nothing else.
            "One of my top five favorite, like, cool...nerd cars"
            '89 325i-sold
            '98 528i
            • rwh11385
              lance_entities
              • 18403
              If they are clogged for real, fuel treatments won't work, or so I was told.
              I got a spare set of stock B25 injectors if you want them fo cheap and then can have them cleaned and have min. downtime.
              • shields
                • Sep 2004
                • 46
                Exactly, It's a pressurized canister that blows through the injectors as the engine runs off it.
                I've seen my mechanic use it. I think I'll just give it to him to do it for me...
                • petone
                  • Sep 2004
                  • 4
                  WTF do you guys mean by sea foam, can you explain exactly what you do?
                  • chrisd
                    • 288
                    I have an industrial ultrasonic cleaner here at work for cleaning parts, think it'd do anything to (er, for) a dirty injector? I can suspend the electrical part up out of the tank...
                    recommendations ? linky?
                    • Jon '92 325ic
                      • 172
                      Get a used se of injectors.....
                      Get a used set of injectors. ($15 - $25)
                      Send them to this guy www.cruzinperformance.com.
                      He'll do this to them http://www.cruzinperformance.com/injsteps.html
                      When you get the cleaned injectors back, install them and sell your old ones.
                      This is Sea Foam: http://www.seafoamsales.com/motorTuneUpTechGas.htm
                      Here's how you use it on an e30: http://www.r3vlimited.com/phpBB2/vie...a+foam&start=0
                      Autozone now sells Sea Foam.
                      I had read about Sea Foam on this board and was curious about it. Then a couple of weeks ago I was at an Autozone and they had a huge display of the stuff. I bought a can (I think it was $5 - $6) and went to my friends house to use it. Easy to use, but you need two people. One on the gas and one holding the can. My car smoked alot for a while but eventually stopped. Afterwards, I noticed the engine running smoother, quieter, but thought I might be imagining it. That night I drove around with my girlfriend (who isn't into cars) but didn't tell her I'd done anything to the car. At the end of the night I asked her, "Did you notice anything different about the car?" I didn't lead her on in anyway as to what change, if any, I might have made. And usually when I ask her this question it's because I've detailed the car or in some way changed the appearance of the car. Right away she said, "Yeah, I noticed it right after you picked me up. It seemed....smoother." So there you have it. An unbiased review. Can't say it improved my cars performance, mileage or tell you with any certainty whether or not it cleaned my fuel injectors, combustion chamber, engine,....... but the car definetly smoked for a while and definetly ran noticeably smoother and quiter.
                      • rwh11385
                        lance_entities
                        • 18403
                        Re: Get a used se of injectors.....
                        Shields, I'll send you mine for $10 + shipping. Likely going to be ~$6.
                        • el_4ever
                          • 145
                          [quote="Jon '92 325ic"]Get a used set of injectors. ($15 - $25)
                          What is the cost on this type of work?
                          • cahomey
                            • Mar 2004
                            • 1201
                            [quote="el_4ever"]
                            more then a bottle of sea foam.
                            • el_4ever
                              • 145
                              [quote="cahomey"]
                              Several times...the end result looks really good.
