I want to run a surge tank in the engine bay that feeds a high pressure pump. however, it is recommended to use a low pressure volume pump in the tank, instead of the stock high pressure one.
i have a late model e30, and therefore i have a single in take high pressure pump. if my research is correct, the early e30s use a dual pump system, one high, one low pressure.
is it possible to take the low pressure pump from an early e30 and install it in my late model e30 tank? is it a direct fit?
