beeping sound?
  • onenicebimmer
    • 139
    beeping sound?
    For the past couple weeks, I have been randomly getting three "Beeps" that come from the lower dash area, on the left side. Does any one know what this means?
    Thanks
  • DaN
    • 1265
    The obc beeps at 36 degrees, is it that cold there?
    • onenicebimmer
      • 139
      No, its like 80 degrees, and I think the OBC beeps in the center.
      Any other suggestions, thoughts, or opinions?
      Thanks
      • DaN
        • 1265
        When exactly does this happen?
        What does the temp on your obc say? Perhaps it's inaccurate.
        Well it would use the chime under the drivers knee bolster.
        • onenicebimmer
          • 139
          Last time it started to beep I looked over at the OBC, and it had the time of 4:32 on it. Then, I switched to temp. and it was at 78 degrees. The sound is three long beebs, almost kind of like when you open the door with the key in the ignition, except its only 3 beeps. This happens at random times. When I was leaving to go to work today it did it, and when I was comming back it did it twice.
          Thanks
          • Super Eta
            • 1884
            You can set the OBC to go off at lets say 65 MPH to let you know that you are above the speed limit.
            Check your speedo next time it does it and then go slower then speed back up to the normal speed you were at.
            • DSchultz325e
              • Aug 2004
              • 1158
              reset the obc
              I retired my E30 for now...
              E46 323i
              David Schultz
              • hotghias
                • Jan 2004
                • 148
                if "memo" is set on your obc, it will go off some number of seconds before every hour, because germans are wierd like that.
                • Jon '92 325ic
                  • 172
                  Is it your casette player?
                  Is it your casette player? If you're playing a casette in the OEM radio/casett player, after so many hours of use, the player will beep like three times and the display will momentarily read "CLEAN" indicating you should clean your tape heads.
                  • onenicebimmer
                    • 139
                    That's it. At first, when it beeped, I looked at the head unit(has the correct time on it), but then I noticed that my OBC is off by like 20+ minutes. So, next time it beeped i saw it.
                    Thanks
                    • e30Matt
                      • 5077
                      Thanks
                      For the first month or so I had an E30 that noise confused the hell out of me. I actually never figured out the problem, as I disconnected the noisemaker under the dash after getting fed up w/the noise when I had the door open, etc.
                      I figured it out a couple weeks later after reading a similar post to this.
                      • Wes325
                        • 563
                        there was a post about this awhile ago when I was having the same problem. I cant remember what it was that was making mine go but it stopped.
                        - 318is 4 life
                        • bimmerphile
                          • 3495
                          it's so you can hear the on-the-hour news updates on the radio.
                          • Spec
                            • Dec 2005
                            • 320
                            Per today's drive:
                            The single beep is 38 degrees.
                            Three beeps? Dunno. I have the same problem and have been wondering that myself.
                            1991 BMW E30 318i sedan
                            2005 Kawasaki 636cc ZX6-R
                            PNWRiders.com
                            • sharkd
                              • Apr 2005
                              • 82
                              I had the three random beep thing happen twice before -- both times on the skidpad. I'm not 100% sure, but it may be oil pressure related? (Maybe -- I still don't know what caused the beeps.)
                              “one of the most beautiful BMW’s ever...”
