O2 sensor Bung?
  • rs4pro3
    • 5808
    O2 sensor Bung?
    Ok I've got a set of E28 m30 downpipes to use on my m30 engine when I drop it into my e30. Now there is no Bung on it as the E28 has the bung on the cat and the Cat has been cut off these pipes.
    I'm wanting to have a bung welded in on the pipes near the manifold like the 325i.
    Now I know it wouldn't be best just to weld the bung to one of the two pipes, So I need to connect the two somehow and then have the bung welded in.
    Any suggestions?
    I may just purchase a Bung and take the pipes to a shop to see what they can do.
    85 325e 2.7 ITB'd stroker
  • brodee
    • Jan 2004
    • 2914
    My headers just have it in one of the 2 sets of pipes, works fine. IF you do it just make sure it's in the set for the rear 3 cylinders.
    "Modern cars may be able to outgun it, but few can match its character, its motorsport spirit, and the way it plasters a huge grin on your face at any speed." - Patrick George
    1988 M3 - Track Rat
    1989 325iC M50 Vert
    1989 325i Coupe
    1991 318is
    1995 318ti Club Sport
    2006 330i e90
    2008 Tundra Crewmax
    • coupeowner
      • Oct 2004
      • 50
      Why on the rear headers only? Is that because it is closer to the heat source (pistons)? Or is there another issue? I had to move my 02 sensor about 8" forward on my headers to solve a Check Engine problem.
      • rs4pro3
        • 5808
        Thanks for the tip, it will make life a lot easier if that will work. My best choice would be to add and X-pipe but to make it effective I need to calculate where it should be in the down pipe. Which I have no idea how to do.
