sounds like a bearing - but it's not... iX
    This is in a 1991 325ix
    So I've got what sounds like a toast front passenger bearing - but it isn't that... The bearing WAS toast, but I just replaced it, and the noise is still there.
    Sort of a tick tick tick, that goes with the speed of the car - the faster you go, the quicker the tick.
    Also, I should note that it stops ticking as soon as I let off the gas..
    What should I be checking here - what chould it be ?
    TIA
    When you replaced the bearing did you check that journal for wear (with a micrometer)? If the journal is out of spec you could have noise from that.
      It was done by a garage - so I would assume they did what was necessary - I'll double check with them, though.
      Anything else it can be ?
        If it is clearly coming from the passenger side, it could be the outer CV joint on the axle. Those are the only major components up there that rotate at the speed of the wheel. Usually the CV joint goes when the boot gets damaged, but they can just wear out over time.
          BTW CV joints click like crazy when they are bad. The balls eventually cause pitting and galling in their races, which makes them snap back and forth.
          Project M42 Turbo
            Pretty sure it IS the CV joint ...
            Whats the best way to fix this -
            Do i have to have the axle rebuilt ?
            Thanks
              any thing i can do other than rebuild the axle ?
                Im thinking you can get a CV joint at Pelican.
                sigpic 1987 325is
                  :stupid:
                  Originally posted by BillBrasky
                  That's like Vlad challenging Chip Foose to a car painting contest.
                  Originally posted by acolella76
                  i'm pretty sure 'Phillis' is short for syphilis
                  2007 CVPI, stock and slow
                  1994 tercel, 5efhe swap, i/h/e
                  1984 t-type, 5.3/th350 swap in progress
                  My newest addition:
                  Rebecca Arlene, born 4/19/2013
