Check engine light comes on after idling at light/stop sign
  • bmwannabe
    • 900
    I noticed a shitty idle today that would bounce down to about 4-500 rpm, back up to 850-900 rpm. Then after stopping at a light, the check engine light comes on after about 8-15 seconds of sitting idle. (yes i counted the time out) When i give it some gas sitting idle, the light quickliy goes off. What could it be?
  • robbieosterman
    • May 2004
    • 199
    AFM? 02 sensor? Sounds similar to when I disconnected the AFM and drove, do the check engine light trick and get the code.
    • Rosica
      • Jan 2004
      • 240
      I had the same problem, which escaladed to what is in this thread
      I still have not fixed the problem, I have a new ICV, Ignition parts, and Coolant temp sensor on order, I wil tell you what worked when the problem is fixed. I will also email you a PDF file which tells you how to find out what engine code is causeing the "Check Engine" light.
      07 335xi Sport
      00 S2k
      01 A4 1.8t-Sold
      88 M3-Sold
      91 325iC-Totaled
      89 325iS - Sold
      87 325-Totaled
      • Nick325is
        • 1409
        Had the exact problem and I found a small tear in the intake boot. A new intake boot fixed the problem.
        Nick
        • bmwannabe
          • 900
          umm i think i found the problem. upon looking under the hood, i noticed i no longer had an oil cap....
          • Rosica
            • Jan 2004
            • 240
            The problem was 2 intake manifold gaskets had disintegrated, car runs perfect now.
            07 335xi Sport
            00 S2k
            01 A4 1.8t-Sold
            88 M3-Sold
            91 325iC-Totaled
            89 325iS - Sold
            87 325-Totaled
