I need to replace the connector and wiring for my AC/Aux fan switch and I understand the original 90deg connector has been discontinued and there is a replacement straight 3-pol connector now. I found this text from a thread from several years ago with part numbers:
The post references both straight and 90deg circular connectors but it's difficult to understand if they're saying both connectors would fit into the straight plug or only the straight circular connectors would fit into the straight plug.
Can anyone confirm if the 90deg connectors work with the straight connector housing? I do not think there is enough room between the ac/aux fan switch and the headlight covers for a straight connector AND straight wires.
Thanks
90 degree connector housing for rad sensor/ac fan switch
61131378412
alternate 180 degree/straight connector housing for rad sensor/ac fan switch
61131378410
90 degree circular connectors for this housing:
61130007445 (small wire gauge .5-1mm) green
61130007446 (large wire gauge 1-2.5mm) green
straight circular connectors for flat coolant sensor housing
61130007441 (small wire gauge .5-1mm) green
61130007442 (large wire gauge 1-2.5mm) green
61131378412
61131378410
Thanks
